I think this turbo is also know as the 6076. I am putting a LC2 into my 67 Firebird and I am thinking of going with a TE-60 P trim. The car has a fresh 109 shortblock with ported irons and the "normal" mods and I will be running a stock location intercooler--not a normal Buick SLIC but similar in performance. The car has a turbo 400 with a Gearvendor overdrive and a 9.5" PTC 3200 stall and 3.23 gears. The car wieghed 3020 pounds with the LS1 in it so I think the wieght should be similar with the LC2. I have never run a mid sized turbo like the 60 before so I am not sure what to expect. I have run TE-45a's, 6776's and PT-70's before and of course stockers but really nothing in between. I have seen people run low 11's with 44's on full wieght Buicks so my thinking is that this TE-60 should be good for low 11's to high 10's on a 3000 pound car and should spool lightening quick with a 3200 stall. Does that should about right? The turbo is rated for 610hp and my goal is 500rwhp with a good solid torque curve which seems doable with this turbo but I would like to get some opnions on if this turbo will do the trick. I know there are some newer style DBB turbos that will out perform the ole 60 but for only $599 brand new the 60 seems to have a lot of bang for the buck!
