I have mine hooked up on a relay. There may be some extra delay, but I just wanted to test it out and not worry about damaging the 2 step. Doug, you can ask Paul about the wiring but as long as you know the wiring for the relay, its pretty straightforward. One wire goes to positive, one goes to ground, output goes to the brown and gray wires on the 2step, and switched power to the output side of the transbrake button. The main thing is to know which wire is which on the relay. When its working, you'll also see the Trig LED turn on inside the 2step box (with the cover off) when the tbrake button is pressed.
Some other things.... make sure you use a good ground for the 2step box, make sure you plug the fuse adapter into the CCCI fuse with the wires pointing right, and I like using the 500rpm partial stutter setting (you'll need to set your launch rpm 500rpm higher with this on). For the timing retard, you'll need to play around. With more timing retard, you'll likely leave with more boost at the same rpm. So it depends on how hard you want to leave. And it does continue to build boost while you are on the limiter, so if you don't have an electronic boost controller you'll need to be aware of how long you are on the limiter at the tree. Just some of my observations from the short time I've used it.
