How to hook up manual boost controller
Darkstar72
It’s fairly straightforward....hose from compressor side of turbo to inlet of controller and hose from outlet side of controller to wastegate fitting. Then you will need to adjust wastegate rod and controller tension to find the boost level you want to run. Start very low and build up gradually.
