Great to see all the homemade oil priming tools, mine is from an old SBC points distributor also.
What other tools have you fabbed up for your TR in a time of need or just for the fun of it?
Here's today's project: wastegate actuator adjusting tool.
* 1/4" or 7mm open end wrench
* 1" or so 1/4" bar stock, check your setup for length
* 4 X 1/4" bolt, nuts and washers for the handle
* plastic tubing for the handle
Cut open-end off of wrench.
Add bar stock to length.
Heat and straighten shank from the closed-end.
Weld and assemble.
Nickle-plating optional. :smile:
Simple operation:
Loosen your adjuster nut, remove the clip, slip the open-end of the tool behind the nut and give it a pull.
Make your adjustment and snug the adjuster nut again.
Another tug on the tool and your on the wastegate arm, attach the clip and tighten the adjuster nut.
Weld and assemble.
Simple operation:
