No.An engine with Factory oil clearances,
Is it recommended to have a high-volume oil pump?
Thin.You will find lots of opinions on this much like the opinions of thin oil vs thick oil.
LOL! But I agree!Thin.
I will absolutely do it my self. Thank you for all the information and taking the time to explain it. I really appreciate it.I recently had a new engine have to come back apart after just fifty miles because of a "new" Chinese timing cover. The shop's entire stock had cam sensor to pump drive bore misalignments. All of the new covers are cast by just one or two places in China, so everybody is drinking from the same well. It's not practical to test every cover on a pallet at the docks, so they're getting to customers. I didn't catch it because they blueprinted and assembled the cover for me, and it was already packed with Vasoline and ready to go, so I didn't check it myself. That was my mistake.
If it has the alignment problem, the pump gears will contact the pump cavity on one side and angle into the thrust plate. The self indexing that happens results in excessive clearance inside the pump and a boatload of aluminum in your oil. Mine was bad enough that the pump drive gear and the driven gear meshed at enough of an angle that they started chipping each other, which sent a few small bits of steel through the motor and scored most of the bearings. They also wore the pump drive shaft hole oblong enough I had to knock the pump gear out with a hammer when I tore it down. My idle oil pressure on that pump was 4-5psi after just fifty miles.
I replaced it with a junkyard genuine GM cover that was still in spec, resurfaced the thrust plate/filter adapter myself, did the Earl Brown mods, put it back together with a standard rebuild kit, and I'm at 70+psi cold startup and 10-15psi warm idle after a 30 minute drive. Standard volume. 5w30 Royal Purple oil. I'm 300 miles into the initial break in, and my pressures are the same as they were the first time I started it, so I think this one is going to make it.
Whichever cover you get, assemble it on the bench with the cam gear and oil pump gears and make sure it spins freely and you have the right side clearance around the entire cavity and through an entire 360 degree rotation of the pump; and proper end clearance across the entire face of gears It's not enough to assemble just the pump gears and check. You have to check with the cam sensor installed. And check it yourself. All it takes is a feeler gauge set and some time.
Trust no parts out of the box. No matter how trusted the vendor. They're being supplied with garbage, and they can't check everything every single time. Nobody is perfect. Stuff gets through.
Yes, thank you so much for taking the time to explain this to us.I recently had a new engine have to come back apart after just fifty miles because of a "new" Chinese timing cover. The shop's entire stock had cam sensor to pump drive bore misalignments. All of the new covers are cast by just one or two places in China, so everybody is drinking from the same well. It's not practical to test every cover on a pallet at the docks, so they're getting to customers. I didn't catch it because they blueprinted and assembled the cover for me, and it was already packed with Vasoline and ready to go, so I didn't check it myself. That was my mistake.
What is the difference between a TA performance booster plate and a milling thrust plate you get from a auto parts place?
It’s all about the tolerances bud . If you can get them nice and tight in the housing with the correct plate spacers you will have a nicely working pump that should last . I have done many covers over the yrs for ppl . Just check out Earl’s write up on moding them and you will be goodAnyone?
Got it.It’s all about the tolerances bud . If you can get them nice and tight in the housing with the correct plate spacers you will have a nicely working pump that should last . I have done many covers over the yrs for ppl . Just check out Earl’s write up on moding them and you will be good
The booster plate is basically the same as milling the bottom piece. The High Volume pump adds a spacer and comes with longer gears.Anyone?
TA doesn't make a booster plate.Your question should be "What is the difference between the Ruggles/Kenne-Bell booster plate and the Melling pump cover surface restoration plate.The booster plate creates a flat surface that does away with the open cavity in the stock pump cover. This creates better pump efficiency,especially at lower rpm. Since bypassed oil is returned to the pump gears through the open cavity and the cavity is no longer there with the booster plate,a channel to reroute the bypass oil back into the oil intake stream is machined into the stock cover with a Dremel rotary tool. The Melling plate is used to provide a new unscarred surface for the pump gears to ride against. The plate retains the open cavity for bypass oil to return to the pump gears,therefore it doesn't do anything to increase efficiency.What is the difference between a TA performance booster plate and a milling thrust plate you get from a auto parts place?
No,the Melling plate is the same as milling the cover to get rid of gouges caused from debris and the pump gears. The booster plate is different.The booster plate is basically the same as milling the bottom piece.
