I am about to start diagnosing a potential problem and would like to see if anyone has seen this before or has some thoughts. I am seeing AFRs in the high 11, low 12 when I crank the boost up to 30lbs. I have made three passes and the MPH is consistently in the low 150s.
Injectors = 120lb Precision
Fuel System = dual feed, Fuelab high volume pump, Fuelab regulator.
Fuel management = Classic Fast - I have the VE numbers at 140 in the upper boost/rpm part of the map.
I am going to verify the regulator is tracking with the boost, but just wondering if I am out of injector or something. The fuel pump claims it can support 1400hp. Injector/HP calculator says 120lb injector can support 1000hp at 85% duty cycle, so maybe I am close to those limits. Does anyone think so?
Thanks,
Thanks,
