The_Bronze
I have been working on a tune (using tunerpro RT) on my 85 T-type (upgraded to 87 ECU and related wiring). I have successfully tuned most aspects of this modified car (small cam, CAI, ported intake and upgraded turbo downpipe) with some success, but have come across a stumbling block. The car has a tip-in hesitation, especially noticeable just coming off-idle, that results in a small "hiccup". It falls on it's face for just a moment and then catches itself. VE table is getting really close, Long terms mostly in the 122-128 range. I stuck my scope on the ECU to see what I could gather and found this:
You can see the injector (in red) start to open on nearly every crank pulse, but more importantly not quite so. The yellow waveform is the ESC signal and the green is the cam sensor. Nothing changes in the RPM/spark side; cam, crank, est, and esc never skip a beat. I am used to the injector on-time lengthening to increase the amount of fuel, this looks more like multi-strike ignition. The on-time of those erratic injection signals is also ~ 1.3 ms, not much time to allow any fuel in at all. Looking through the .bin I don't see any fields of asynch pulses or such that might account for it. This happens each time I give it a decent stab of the throttle. The above waveform is with a stock 87 GN tune in a separate ECU. The result is the same if using my socketed ECU and my custom tune. Any ideas?
