help with scan master #s please
yelowta
I just installed my lt1, maf gen 2 translator with pnp adapter and extreme G chip from TT. my numbers key on engine off are
AF 01
L8 00
BAT 12.3
INT 14
BL 08
MPH 000
CLT 173
ATS 71
R 000
TPS 32 Was 42 before I ran car up to temp.
IAC 150
MAL 22
With car running
O2 420-440
AF 11-12
L8 99-113
BAT 13.8-14.0
INT 128
BL 128
CLT 185
ATS 71
RPM 950-1025
TPS 32
IAC 11
MAL 22
The car was running good before I installed these things. Have about 400 miles on motor I haven't put more than 8lbs of boost to it yet. I do most of my own work but when it comes to reading these numbers and adjusting i'm out of my element. I appreciate any input car is running pretty rough and blowing lots of smoke out of exhaust, on a good note mosquitoes are probably gone for the day.
Thanks Ron
Make sure the Gen II is set up like the following on the Configure Select menu:
Thanks Eric. That's what I needed. Runs better and no smoke just needs a little tweaking. Now if it would stop raining I could take it for a ride.
