Erics 5.7 street chip...91 octane.. 19 degrees low gear timing...17 degrees high gear timing...50 lb injectors. Has about 14 to 15 pounds of fuel in in it...depending on the turbo...heads...IC etc.
Erics 5.7 street chip...91 octane.. 19 degrees low gear timing...17 degrees high gear timing...50 lb injectors. Has about 15 pounds of fuel in in it...depending on the turbo...heads...IC etc.
