black cars boosted
new guy on tha bloc
- Sep 23, 2018
I purchased my second GN and its been sort of a nightmare. when starting no fuel pump, but priming port works and pumps work. have spark out of coil pack and power to injectors but noid light placed and there is no pulse no injector spray.. ecm?? car has hotwire kit but 2 relays. one at the tank end and one placed along the driver side fender and is using alternator connection along with fuel pump priming port. there is some type of pressure switch in between using vacuum. now there is also a old speed pro fast track ecu.. and the oil pressure switch and the oil sending unit has 2 wires that are ran back through firewall and there is a capacitor utilized. maybe someone out there has seen this system.. the car was said to be a duttweiler built car.. front mount intercooler,different turbo,at least 3" up down and complete exhaust and dump pipe.. low mileage car.. what should i do??
