Help identify this connector
jmendlik
What is this connector for and the wiring diagrahm?? I searched the board with no luck. Anyone???
It's located under the dash by behind the vent below the steering wheel-once the cover is removed you see the underside of the steering column. I'm trying to figure what these wires are for as Im having some issues with fuel pump prime when you first turn on the ignition key.
339698
339699
