8 8TurboT7 Team Legion Joined Apr 11, 2007 Oct 19, 2007 #1 I checked all the fuses and the head lamp and I dont know what to do Can someone help me?????
B BlackMetal Active Member Joined Sep 29, 2005 Oct 19, 2007 #2 Check all your grounds. I had a problem where with my low beams on, the high beams were glowing dimly too and it was a loose ground causing power to backfeed through the high beam circuit.
T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Oct 20, 2007 #3 Do the runners work? Do the brights work? Could be the bright light switch.
8 8TurboT7 Team Legion Joined Apr 11, 2007 Oct 20, 2007 #4 eveything works but the headlamps, I'm going to check the ground
