Bucket seat information
86 TR
Work In Progress
Just finished installing abs foam backed headliner. Now they're is indentations in the foam. Will these come out?
Looks really crappy. But how else was one supposed to get that thing in there. It's a hardtop
Sent from my SM-G960U using Tapatalk
If the fabric was already installed when you bought the board you should be good. The only time you are screwed is if you go pressing down right after you glued the fabric down.
Try using a blow dryer on low heat on the wrinkled areas. Keep the blower moving back and forth, don't concentrate the heat on one area for long.
