J john saleeby Active Member Joined Aug 5, 2006 Sep 23, 2018 #1 Lights flicker when GN is idling and when driving. Any ideas as to where I should look to find cause of this and how to remedy?
Heskahoka Supporting Member Joined Sep 10, 2012 Sep 23, 2018 #2 Two leading contenders: 1. Alternator going bad/voltage regulator. Get the alternator checked at someplace like autozone. 2. Bad ground somewhere, Check the ground points near your battery on the passenger fender and the firewall. I am leaning towards the alternator, more likely.
J john saleeby Active Member Joined Aug 5, 2006 Sep 23, 2018 #3 Thank you Hes. Will start there at alternator and grounds.
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Sep 24, 2018 #4 Check the pos cable, near the down pipe. If it's toasted, it could be doing an intermittent short to the pipe.
