header gaskets
I have heard that the "Remflex" gaskets are the ticket for the exhaust.
Available from TR custom.
I won't use anything but Percy's aluminum. Expensive, but worth it. Burn proof, will seal irregular surfaces.
I like the TA Performance set.
If you are just doing a change.
Those chrome looking ones you found look nice but expensive.
If you have a bad leak, warped header flange the Remflex will hold better for a while but not permanent.
Or you could buy 2 stock cheap $7 gaskets from the auto part store and stack em.
Honestly, I would pay $100 for a set if they guarantee me not to blow out. I blew out a set of Felpros on my TTA in 6 passes and doing 8 hours of car work isn't fun...
The headers will be machined flat.
So the second link?
yep..... second link.
Seal-4-Good Buick Stock V-6 231-252
Product Code: 66045
Price:
$44.88
Buick heads and TTA heads are different.
Send the headers to get surfaced.. use orange RTV.. and install them. You shouldnt need gaskets on factory manifolds.
I used the Felpro's on my TTA and never had an issue. They where for the 3.0 FWD Lesabre.. like 1986
Julio, I had the TTA headers milled flat and then used the Felpros (the ones you recommended). Blew out after 6 passes. Pulled it apart and had them milled again then used copper RTV and 60 passes later no issues. The tta won't see gaskets on my car I had such and awful experience.
Maybe I'll do the same for te GN. Althoight those Percys look good.
Input?
felpro 1400's here!!! i am on my 4th use of the same gasket with no issues and leaks. i use a thin film of copper rtv and they never stick or burn out
Should you re-torque header bolts occasionally to prevent the gaskets from blowing out? What should the torque be?
