Head gaskets $21.95!
This may have a steel fire ring, but does not look like a steel shim gasket?
Does NOT have any reference that this gasket can be used in a turbo application?
Also, the bore size is for a 4.1 or larger.
The original GM steel shim gasket is 0.018" thick, not 0.042".
As the saying goes, "you decide"! ;)
4.090" bore? I wouldnt want all that added clearance volume. Doesnt look like a good gasket. Id find it hard to believe that they could even make a proper gasket with the steel ring in it that cheap.
the price is cheap becuase it is a closeout of old stock, 4.090 is not a big seller, they need to go. It is a very nice gasket but has not been made for years and this one will not fit anything most folks here have
Mike
