MNcarbturbo
What's Fuel Injection?
- Mar 9, 2009
Just finished my swap and dealing with a dead miss on cyl 1& 5.
4.1 with a 86/87 setup in a G body cutlass. I had pieced the setup together out of boxes that I bought from the guys widow. I had the engine in another G body running for 2 years with about 8k miles on the setup and pulled the engine and sold the roller. Just got it installed in another G body.
All this stuff was new in 19
MAF translator and LT1 MAF
Dynamic LS coil near plug conversion
Casper's cam sensor cap LED
O2 sensor
The engine ran great for 2 years and the only change I made was what car it's in, it sat on a pallet for 18 months.
The wideband (new last fall) located in the downpipe reads dead lean (18 afr+) while the narrowband reads 350-450mv at idle
Scanmaster shows no codes
Compression check shows 125-140 psi on all cylinders. Cyl 1 & 5 are cool when checked with a heat gun.
I can unplug coil #1 and #5 and it makes no change to how the engine runs. It will backfire hard and die if I unplug coils 2, 3, 4, and 6.
I swapped plugs between cylinders and the problem stays on 1 & 5. I have nice hot spark on both. Plugs don't look wet but have a good amount of black soot on them.
I checked the injector plugs with a noid light and I get pulse. I checked fuel pressure and it's good. I swapped injector 1 & 5 with another pair (car runs 37lb GTP white injectors) and no change. I pulled the fuel rail out of the manifold and blipped the injectors with 12v and the pattern looks good.
I swapped ignition modules with another one I had on the shelf and no change.
I checked and reset my cam sensor position and it didn't move from before.
Unplugged the MAF and it made no difference.
The car will die immediately if I unplug the cam sensor after it is running. It doesn't like batch fire mode?
Any thoughts? I'm stumped, it feels like the fuel timing is wrong. I'd rather not parts cannon it. I just don't know where else to look.
O2 sensor
