GN # 2 getting painted.....
NOTSOFAST
well GN #2 is getting painted :D as I deal with GN #1 no start problem. :mad: But I believe I have GN #1 sorted out. :) I will post pics shortly of GN #2 at body shop. I will be adding 18in x 9.5in all around , if the offset is right on the wheels im looking at.
May want to remove any O2 sensors and plug the holes. More so if there is a WB O2 sensor on the car. For some reason paint shops tend to ruin o2 sensors. Can use a 18mm threaded spark plug to plug the holes (Autolite 386 works).
Can't wait to see the results of the paint...
RemoveBeforeFlight
If you have a photobucket or some other online account to upload photos to, you can post links to the photos from where you uploaded the pictures to.
Have them remove the backseat side windows and the attached rubber moldings before prep/painting.
Otherwise they mask it and the paint finish is irregular in that area.
