psycho6cyl
Ponies Are For Lil Girls
- Feb 11, 2005
I've searched and searched and I'm dizzy. Looking for some advice. Will be installing a ractronix double pumper w a/n fittings. I know I have to run a -8 feed and -6 return. I will probably going champion rails w remote regulator..
If my understanding is correct I will duall feed the (front) rails via a Y block off feed. I will need a Y block to tie both rails in to go to regulator.
Do I need a check valve on the feed? I know I will need a filter. Do I need a filter on return as well?
Also what's a good remote regulator to run? Please help me understand it. Hopefully I'm right.
Goals is mid to high 10s w 80lb injectors and 6466 turbo. Thx
