TylerDurden
Jack's Smirking Revenge
- May 24, 2001
Background, I have been trying to chase this down for over 8 years. It started out as the car died while driving one night. Towed it home and attempted to trouble shoot. (its been so long i dont remember what that entailed). Since then I have replaced the pump, walbro 340, I replaced the previous owners hotwire kit with caspers. I have replaced the in tank wiring and pig tail to the hotwire relay. I have also replaced the fender fuel pump relay.
right now the car will not prime.
But I can use the "fuel pump prime wire" at the alternator and get the car to run, but when i disconnect that wire, the car dies.
the original oil pump px sending harness is not in play anymore.
I tested the ground at the front FP relay harness at 4 ohms direct to the battery, and when you turn the key fwd, i hear 2 clicks at the relay, approx 3 seconds between the ON click, and OFF click. I tested the other two connectors at the relay with the key fwd and got 9.4 volts, these are the wires that come from the fuse box and go to the 12v lead to the rear pump relay (hotwire relay). when i took the hotwire kit out of the equation and connect the 3 prong weather pack from the tank to the orig 3 prong connector i still get nothing. I have not had the opportunity to use another person to turn the key fwd while testing voltage with the orig 3 prong. thats next on my list.
My overall question is why will the car run with the FP prime lead at the alt, but die when disconnected? I thought it would have everything to do with the fuse wire to the relay or the wire from the relay to the pump, but seeing 9.4 volts with key fwd kinda shot that theory down. Granted the voltage is low, and that is probably due to multiple start attempts and door being open causing what was a full batt to weaken. I will charge the batt up and do that test again to verify that voltage. But I have had the batt at full charge earlier this week and still could not get it prime.
Another question is should the front fp relay click when I connect the hot lead to the alt, someone mentioned it should but I see no reason why. I would expect the rear relay to click when I do that, but have not had the 2nd person avail yet to test that theory.
thanks in advanced for any help on this gremlin
