fuel pressure seems to be raising 1 to 1. but it starts knocking at half throttle. I do have a hotwire kit. Key on getting 11.6 volts to the pump. i did notice when i turn key on i hear the pump run then stop but fp gauge is still at 0 psi until i start it. bl at cruise is 122
You claimed with the key on you're getting 11.6 volts to fuel pump; is that key on and engine running at first start?
What voltage do you get when engine is warm?
What voltage do you get when you are driving it normal?
Are all ground cables including the hot wire ground fully secured to engine block and chassis ground?
Your voltage might be too low for the fuel pump to run it operating level
