Fuel lines
buddy
Does any know of anywhere online that I can get a complete set of fuel lines for my 86 T-Type? My supply line that is directly behind my rear seat has a pinhole and I figure I'll replace them all while I'm at it. Is it true that you need to run stainless if you plan on running E-85?
Make sure they know all the correct sizes. I got burned once. Ask questions! !!!
http://www.racetronix.biz/items.asp?Cc=FLK&iTpStatus=0&Tp=&Bc=
Got mine from racetronix. Really nice stuff, they also pre measure and label everything for you very nicely. They used to have three different options for quality/cost now it looks like just two. Comes with a badass fram fuel filter housing and e85 compatible fuel filter. They're -8 -6 return, good for e85
I replaced my fuel and brake lines from inline tube. Lots of fun while on jack stands and the body on the car.
http://www.inlinetube.com/Preformed Lines/Web Line Listings/BK-CAT-12.htm
you do not need stainless for E85 but it's nice to have regardless. Not much too more $$ and it looks nice.
For the guys that bought from inline tube. The description is somewhat vague. On The listings under our car, they make it look like each item is for the vapor and return that run full length passenger side, and the feed that goes from above the rear frame to fuel filter. Does that look right.
BKF8301
BKF8303
BKF8304
So would these be a complete set besides the two that run from near the firewall to the fuel rail feed and return??
