For Sale: 1987 Grand National - Immaculate Condition - Fort Worth, TX - $38,000
Trader history for gn87man (0)
gn87man
1987 Buick Grand National
Hard Top
Excellent condition overall
They don’t get much cleaner than this one
Over $50,000 invested in the car
Originally a Southern California car
Car has always been garaged and has never seen rain
Always adult driven and extremely well maintained
Car runs, drives and rides excellent
Lots of horsepower add-ons
Approximate horsepower at flywheel = 625-650 HP
I am the 4th owner
Clean Title with Carfax
The body/chassis of the car has about 124,000 miles on it
Note: The GNX style instrument panel (described in the interior section below) was installed when the car had 80,000 miles on it in 2002. When the GNX style instrument panel was installed, the odometer was reset to zero. The current odometer reading on the GNX style instrument panel is 45,500 miles. That means the total mileage on the body/chassis of the car is about 125,500 miles (80,000 + 45,500 = 125,500 miles). However, the new (fully rebuilt) engine has about 700 miles on it and the new (fully rebuilt) transmission (along with new 3200 NLU PTC converter) has about 30 miles on it.
Interior: I would rate it at 9.8 out of 10
  • One small crack in speaker cover on top of dash on driver side (see picture)
  • Everything else is pretty much perfect
  • GNX style dash with VDO gauges (white face)
  • Pillar pods with Casper’s knock gauge and PLX wideband gauge
  • Pioneer in-dash mp3 radio (7” flip - touch screen)
  • New stock size 6.5” and 6.9” speakers
Exterior: I would rate it at 9.5 out of 10
  • Extremely clean with No rust
  • Car was repainted about 14 years ago
  • Recent paint correction performed
  • Paint is show quality
Engine: 3.8 Liter (231 cubic inches) – V6 Turbocharged
  • Rebuilt engine with about 700 miles on it (Built by top rated engine builder (in Texas) for these engines)
  • Stock 109 block
  • Stock stroke
  • Bored 0.030” over
  • Billet center main caps
  • Forged Scat crankshaft (4340 Steel)
  • Forged Scat connecting rods
  • JE pistons
  • Comp 212/212 cam
  • TA lifters
  • TA roller rocker shafts
  • TA roller rocker arms
  • Custom push rods and springs
  • High volume oil pump
  • Custom valve covers
  • Stock plenum
  • RJC power plate (for plenum)
  • Stock intake
  • 83 lb Siemens injectors
  • TA Intimidator ported and polished aluminum race heads
  • RJC “Bullet Proof” head gaskets
  • LS1 MAF Translator
  • Accufab adjustable fuel regulator
  • Casper’s volt booster
  • Recently rebuilt cam sensor (to better than factory specs)
  • New crank sensor
  • RJC heavy duty engine brace
Turbo: Precision 6466 built by Bison – internal wastegate – heavy duty style actuator
Manual Boost Controller (built by Earl Brown)
Turbo Saver system
Transmission:
  • 2004R - Rebuilt Stage 1 transmission with about 30 miles on it (Built by top rated transmission builder in Fort Worth, TX)
  • Transmission is rated for up to 750 horsepower – it contains the billet forward drum
  • Deep pan installed on transmission – holds about 11 quarts
Torque Converter: Brand New - PTC Non-Lockup 3200 stall – 17 blade (Spec’d by Dusty Bradford) - Has about 30 miles on it
External transmission cooler
Intercooler: GN1 stock location
Turbo Tweak Chip (version 6.1) – 91 octane fuel with alky injection
3” MAF pipe with cold air intake (with K&N filter)
Auto Meter mechanical fuel pressure gauge (hood mounted)
PLX wideband system
3-bar MAP sensor
Scanmaster
Powerlogger
3” down pipe
TA stock style headers and crossover pipe
Straight pipe
Unrestricted 2.5” hooker dual exhaust
Seabring mufflers
Full Hotchkis rear suspension
Upgraded KYB shocks on front and rear
Upgraded suspension springs on front and rear
Moser axles (28 spline)
Alcohol injection system (single nozzle) – Alky Control system (by Julio)
Holly Sniper EFI Fuel Pump (340 LPH) with hotwire kit
Fuel tank was replaced about 8 years ago
Air Conditioner: Converted from R12 to R134A – works great
Fully carpeted trunk kit
Brakes:
  • Powermaster style brake cylinder converted to newer master cylinder style (vacuum style brake setup)
  • Front disc brakes and rear drum brakes
Alradco Headlights – Low/High Beam HID kit
Stock (Factory) Wheels
New Battery
Tires:
  • All tires have less than 300 miles on them
  • Front ==> Nankang – SP-9 Cross Sport – P225/60R15 96V
  • Rear ==> Mickey Thompson – ET Street R – P275/50R15
Miscellaneous:
  • Electric windows
  • Electric locks
  • Tinted windows
  • Cruise control
  • Tilt wheel
All paperwork/receipts from previous owners and my upgrades included.
$38,000
Please message me with any questions. Thank you.
gn87man
Exterior pics...
20200621_190143.jpg 20200621_190110.jpg 20200621_190114.jpg 20200621_190119.jpg 20200621_190311.jpg 20200621_190323.jpg 20200621_190346.jpg 20200621_190351.jpg 20200626_194922.jpg 20200621_190235.jpg
gn87man
Which company built the motor and transmission?
Tommy Phillips built the engine. He is a local builder here in Fort Worth, TX. Ken White ("Limited T" on this forum) referred me to him. Tommy has been building these engines and many other types of engines for over 30 years. He is 82 years old. He really knows his stuff. Ken White can vouch for him. If you don't know Ken White, he has the fastest stock block turbo Buick in the country.
Jason Henderson built the transmission. He is also a local builder here in Fort Worth, TX. Ken White referred me to him too. He has built many of these transmissions over the past 20 years. Ken White can vouch for him too.
Let me know if I can answer any other questions.
Thank you.
GNBRETT
Pelennor Fields
Now THATS how u list a fucking car! Probably the best for sale ad Ive ever seen anywhere! Car is dope!
