Flex Fuel Sensor
Mike E
Mr. Badwrench
I have a flex fuel sensor I'm not using. It comes with -8 fittings and the GM harness. $125 shipped.
The sensor is brand new from Innovative Motorsports. Russel 3/8" GM QD to -8 fittings. There are -8 tube nuts and ferules on in the picture in case you want to plumb this into hardline. I will included some XFI pins if you need them to hook this into the ecu.
I'm interested. Can you advise what other parts would need to be purchased. I would like the option to run either E85 and 91 octane or mixture of both.
You just need to plumb this into your fuel line and hook it up to your ecu. It hooks to the aux shaft input on xfi, not sure where it goes with the stock ecu chip setup. I have pins for both setups.
