Fixing up a hot air engine
Turbo_warpony
I have an 85 T Type WH1 that I'm fixing up. I already put in a new fuel tank, fuel pump, fuel injectors and adjustable fuel pressure regulator. I just got these parts, cam sensor cap with LED indicator, cam sensor fix module, hotwire kit for fuel pump and a set of comp cams valve springs. I'm trying to find a good set of valves for my head's as well as retainers and such. I'm also looking for a good set of head gaskets and head studs. Does anyone know where I can find these parts?
TireFryer
Now I know how clouds are made...
Take the heads somewhere to get done properly. Can't just throw valves in it... I used felpro 9441pt geadgaskets(stock style graphite) and run 28 psi on 93/alky with no problems. If you're looking for head studs, use ARP, put the bottom 4 in, then the head, then the top 4(with the heater box you can't put the head on with all the studs. I used arp head bolts. Put Loctite 567 on the threads to seal the head studs or bolts.
I have a 1986 wh1 :eek:
ShaunKris
#PROJECT84FORIA
Don’t use the 87 studs either. Look for the stage studs, they’re shorter. AND, port yer heads, intake, etc! You’ll wake er’ up!
turbobooster
Who do you guys recommend taking heads and intake too to have them ported and polished right?
ShaunKris
#PROJECT84FORIA
I wish I could help ya, I ended up having to do my own. There are a ton of very knowlegeable people it these groups, and there are lots of technical help articles here and on other buick forums.
turbobooster
So what would be the beat port and polish option to a stock gasket or the felpro 1200 ? Another question how do I get ahold of bison? Tried messaging him but no luck in response yet boost231?
MikeS
The contact number on his Facebook page is 203-640-2126. Last time I contacted him via text message he was prompt in responding.
Boost231
What's An Intercooler
Staff member
if you have facebook he will get back to you quick
TireFryer
You can do it with stockers and lots of boost. Get champion ported heads and self portmatch the intake to the head ports and you won’t need nearly as much boost
turbobooster
Ok so did some online searching for champion heads found champion ported iron heads through cotton perf and hartline perf just the 2 I’ve looked at this might be a dumb question but it doesn’t specify what years they work on? Are hot airs and intercooled heads the same thing?
