I first bought my 87 GN when I was 18 and have had it for the past 14 years. I frequented the track for the first few years when I got the car and had it really dialed in with race trim (see sig). I finally finished med school, residency and fellowship and now finally have time to enjoy my GN. After all of the maintenance stuff was sorted out (after only putting about 50 miles on it during past 12 years) I headed to the track.
I was more concerned about just getting a good baseline street tune. Was running a TT 93 octane street chip and 100 octane unleaded gas to be safe (stock cat in place). It was 60* out.
Tonight car had stock catalytic converter installed (from my last emissions test in like 2002), I wasn't able to install my test pipe or run an open dump before heading to the track. I know this probably killed my performance.
First pass was 13.3 @101 with 1.88 60". 18 pounds, unlocked stock TC, 44psi line off FP, 0.9 knock, O2 in 3rd gear at 710.
Second pass was 13.5 @ 100 with 2.1 60". 18 pounds. I cranked up FP to 46psi to get my O2 up. O2 was 720.
I increased my FP further up to 48psi to try and get my O2 up in the 750 range, but it was still in the 720-730 range.
Since I didn't have any significant knock readings I tried turning the boost up a bit (2 turns on my cut stock wastgate) and my boost was way out of control up to 23-24 pounds with 5-6 degrees knock.
I finally got the boost back down to the 17-18 pound range and the car clicked off another 13.3 @ 102.
One my last pass I did the paper clip trick and locked the converter. 13.3@104 with 2.3 60" time.
So I have a few questions.
-Are the O2 readings of low 700's concerning? Even at 48psi line off FP I was in the low 700's. Time to upgrade the stock injectors? The car has the hotwire kit and aftermarket fuel pump. I have been over 110 mph with these stock injectors in the past without issue.
-How much mph gain do you think would be seen by installing the test pipe or a dump? I have a 2.5" high flow cat back exhaust. I know that the stock cat robbed me of at least 2-3 mph.
-My rear airbags would not hold any air. They were deflated for almost 10 years. All the fittings are intact. Guess the airbags just dry out and crack over time?
-I guess I am just concerned that my mph was so low. But I guess the car ran pretty good for first time out after all this time.
