First time at the track tomorrow should I still spray meth?
sdteb
trying to get it like you
I have 120’s , tr6 ignition
450 pump with the racetonix lines, 6262 bb new ported heads and intake with big valves.
Car went 7.10@ 96 on pump and alky.
Question is should I spray meth still?
Got good tested e80 from our new station
Mr.Spool
I dont think you should.
I think the car should be tuned properly on e80 or e85 before you track the car.
Heskahoka
Supporting Member
I wouldn't. The whole reason you went E85 was so you would not have to spray meth. It sounds like you have enough injector and pump to keep it safe.
I have a similar setup and have been good with the E85 all the way down to E60.
Turn your boost down and log your runs. Based on data, creep up onto higher boost.
sdteb
do you guys think 45lbs line off is a good start point for fp? thats what i have read and have her set @
sdteb
will o2's in the 760-800 range be a goo measure third gear?
Sweet6
45-50lbd base seems to be the range. I run about 48ish. But depend on your set up too.
GNVYUS 1
I would keep the Meth in case you run out of injector. I would tune it first 100% E85, then if needed in the future for injector headroom I'd tune the Meth in to stay away from 90%+ IDC pulls around your desired AF/R.
