First ScanMaster Readings
Joeld
o2 Mcv - bouncing from say 115 to 600, primarily around 580-600
retard 0.0
TPS at idle .34
Any input is appreciated.
Motor is 100% stock, right now has stock fuel pump, stock everything, I've done spring cleaning and installed vacuum brakes that's about it.
I did put in platnum plugs and a buddy told me they are too hot and I will replace today.
Thanks guys,
Joel
fix your TPS its outta whack.... get it between .42-.46
other numbers are normal at idle.... make sure your CC [cross counts] are bouncing and jumping frequently
Get rid of the platinum plugs. Use the forum "SEARCH" feature... lots of good info on plugs, gapping, pretty much whatever
aaron
Thank you very much for the super fast response
Yes i knew better on the plugs but rushed and it was all they had
Thanks again aaron
Joel
