Feedback about roller camshafts
I run scorpions on my GN1s for 8 years no problems. The shaft mount T&Ds are nice. They just cost a lot more. When I last looked they were $800 and that was years ago. Not sure what they cost now.
HARLAND SHARP.
LIFETIME WARRENTY.
Bought 2 sets. Not building a backup engine, as I got too good an offer to pass up for the car. I'll split the shipping. Still in original packing. 1.65 ratio.
TIMINATOR
HARLAND SHARP.
LIFETIME WARRENTY.
TIMINATOR
for irons or GN1?
I thought the OP was planning on GN1s unless he changed his mind.
But if irons the HS are good.
I really like the TA performance/T&D roller rocker arms, came with everything to install and solid shafts. I use the 1.65 ratio on my 206 comp roller cam.
what lift cam from Bison ? and what rocker ratio did he recommend ? I too have the TA but in 1.5.
Lift is 0.330/0.325 duration is 218/212 on a 112 lobe seperation. We are going with 1.60 rockers.
the extreme energy lob is a nice lob.It is more than I would run but Bison is the man. And in the famous word of Larry GETTER GONE.
What does everyone's car idle at with a roller cam? Right now I can get my stock motor with 120 pound injectors to idle at 800 rpms. Just curious if its possible to get a cammed car under 900?
There’s a trade off between overlap and richness. More overlap will require a richer idle in order to be stable, as well as more speed. More displacement and more static compression helps idle too.
850-900 rpm is pretty typical.
950rpm on a 109 with 224/224 on a 110lsa with 160’s. E85 @ 8.5afr Choppy but stable
850rpm on a 109 with 215/220 on a 112lsa with 120’s. E85 @ 8.5afr Smooth
850rpm on a TA block with 225/225 on a 114lsa. 160’s E85 8.5afr smooth
