hemi8
Goin Sideways
- Jun 6, 2001
Does the FAST system need/use the VSS signal? Reason I ask is I'd like to remove the speedo cable and signal generator and use a GPS speedo.
Also, can I ditch the factory cam sensor/crank sensor/ignition module and coil and use the Electromotive Ignition system with the FAST system?
Mike
Mike
