FAST sequential with Racetronix Double Pumper
Mini
Just confirming, the FAST Sequential system will control the on/off of the second pump with the Racetronix Double pumper?
I was advised the Aux.#2 will, based on MAP and TPS inputs. Any issues using this over the optional Hobbs switch?
Thanks, Mark
HighPSI
Moderator
Staff member
You're taking about the xfi. Yes, aux 2 can trigger a relay fur the second pump.
Mini
Appreciate the reply, it's actually a FAST classic. Will Aux.2 work on it?
I had spoken with you last year about a tune, finally putting it in now.......
I hope to install and get ahold of you in near future.
Thanks.
Racetronix
Thanks.
The first gen FAST PCM will does not have AUX outputs to control a secondary pump.
Mini
Gotcha, I had been told it did, glad I followed up.
Gonna order it with switch and harness.
Thanks,
Mark
