Fan Relay Question
Kyleh24
86 GN , 87 White T
I have a stock 86 GN with a TT chip, and a 87 T with some minor mods, that also has a TT chip. The 87 T fan runs for 5 seconds after the engine is shut off, every time. (I have read all about the delay relay problems and have a spare stock of all 3 relays). Question is; Could the chip be doing that and it be normal? I have had no dead battery issues or anything. I am just wondering why the 87 does it and the 86 does not. Thanks in advance...Kyle
Kyle--a lot of guys just unplug the fan delay relay due to all the potential issues it can cause--even when you least expect it. Such as--running the fan until the battery dies in the middle of the night; or shorting out and causing the fan to stay on all the time while driving. If it bothers you to run after the engine is shut off--just unplug it. Mine never runs after shut off--I have a dual fan set up with a 160 degree thermostat. Go figure. Dp
Its an early 2000's Stratus assembly. 17x26x3 are the measurements and its 2-speed setup.
