Leightoning
Im hoping some of the experts can help Me figure out my car.
I have a wideband afr and boost gauge on my car. If I mash the gas pedal (not even having to go wide open) it falls on its face for a split second and reads very very lean. It then will pick up and build boost just fine (around 9-10 psi) when it is under higher boost, it reads further rich than the gauge can even go. (It still pulls very good though)
My first assumption is the PEVR may be bad. Or I have vacuum lines in the wrong spot?
May even need to adjust the secondaries on the carb.
Let me know if any of you have advice for me. Can provide more info if needed.
Thanks!
Thanks!
