I hate to tell you this because I know you want a jump on things. But I would wait until the rear is in and measure it up then.
When I swapped to a TH400, I used a balanced driveshaft from an 8 second Buick with the exact same set-up. The shaft was 3/4" short of the acceptable range. I didn't know why I had such a bad vibration while cruising. I jacked it up, put it in gear, watched it spin, and could see the wobble on the trans output shaft. Had to have one made. I think I went with 1-1/8" longer.
