engine mounts
I have an 87 --442 and an LS engine for it. Have not pulled the V-8 Olds yet but it appears that it has the same or close to the same motor mount as the TRs I have owned. What is the preffered way to mount it in the engine bay. Would it be as simple as using SBC adapter plates and SBC motor mount for a Monte Carlo. Thanks--Lee
Stock v8 engine mounts frame side and Holley ls mounts on engine is what I used and the 6.0 fits perfect. You will need an oil pan too. I used Holley also,302-2.
