Engine management project
calais1965
Starting new engine management project for two motors
Syvecs ecu will control Boost,timing and spark and it will have three different power level programs with launch conrol.
All original wiring will be taken out.
Parts used:
-Syvecs S6 ecu
-Bosch high-z cng 1700cc injectors for re85
-Aem ign-1a coils/coil per cylinder
-GM flex fuel sensor
-4 bar map
-NTK wideband lambda
-EGT sensors
-Bosch knock sensor
-Bosch oil&fuel pressure sensors
-GM iat
-Pierburg boost solenoid
-GM wheel speed sensors
-Bosch crank sensor
Drawing for 60 teeth trigger
Nice ECU! I'm a big fan of them so far, they appear to be bulletproof and come with lots of features. Expandable to control GDI and other things. Very Cool for the price.
Way over my head, I'll stick with a plain jane XFI.
4 pcs 60 teeth trigger wheels for ta-performance harmonic balancer ready, pics coming soon.. Wiring harnesses should be ready next month.
The project has moved a step forward.
Trigger is completed and the fuel pressure reading.
everything looks nice cant wait to see it running .whats that senser on the fuel rail.?
Cool, but what are the bungs right at the header/turbo flange?
