Emblems, knock gauge, cam sensor/tool, and more!
SouthernCal GN
I come in peace....AK AK
Cleaning the garage- parts a plenty! Let me know what you need.......
NEW/NOS
1) 2 NOS "3.8 SFI TURBO" emblems (w/blue backing tape) $30 each + ship
2) 1 B&M Unimatic automatic floor shifter $75 shipped
3) 1 cam sensor assembly $94 shipped
4) Casper's cam sensor tool $30 shipped
5) NOS 1987 gray "T" horn button assembly with mounting screws $85 shipped
6) Small K&N filter for passenger valve cover $12 shipped
7) steel OE spec timing set (gears and chain) $40 shipped
8) Window rattle elimination kit $30 shipped
9) Edelbrock rear tubular braces (w/ instructions, no hardware) $60 shipped
USED
10) 2 good/very good "3.8 SFI TURBO" emblems $10 each shipped
11) 1987 TR/GN power steering reservoir with bracket $40 shipped
12) Black on black Casper's knock gauge with mount $65 shipped
13) turbo up-pipe painted (no holes) $15 shipped
14) 2 good stock 86/87 ECMs with calpak chips $60 each shipped
15) coilpack/ignition module assembly with wires and mounting bracket $125 shipped
16) 2 passenger side relay assemblies with ESC/MAP/relays $25 each shipped
17) 2 IC fans with brackets- 1 painted black, 1 stock $15 each shipped
18) factory header/crossover assembly- no cracks- with EGT probe installed $285 shipped
19) stock rear lower control arms with factory swaybar $50 + shipping
20) 1987 GN instrument panel assembly- 80k miles $125 shipped
21) Instrument panel surround- good driver quality.
22) 2 factory cooling fans- 1 stock, 1 modded (high speed operation only) $40 each + shipping
23) 87 GN dash w/ducts and glovebox- foam is soft, no cracks or tears in material. $200 + ship
24) ported 8445 heads- 1 needs to be welded - ask for more info
paypal is fine.
Pic files are big- I can send them whoever needs pics. Thanks!
Caspers cam sensor tool
Hello southerncal gn: I would like to buy the cam sensor tool if it is still available.I have paypal; just let me know how to send it to you. Thanks Jerry Berger
Update
Cleaning the garage- parts a plenty! Let me know what you need......it may be hiding in the shed.....
NEW/NOS
4) Casper's cam sensor tool SOLD
5) NOS 1987 gray "T" horn button assembly with mounting screws SOLD
6) Small K&N filter for passenger valve cover SOLD
USED
10) 2 good/very good "3.8 SFI TURBO" emblems SOLD
16) 2 passenger side relay assemblies with ESC/MAP/relays $25 each shipped 1 available
17) 2 IC fans with brackets- 1 painted black, 1 stock $15 each shipped 1 available
paypal is fine.
Update #2- more stuff!! See Below!
NEW/NOS
3) 1 cam sensor assembly $94 shipped SOLD
7) steel OE spec timing set (gears and chain) $30 shipped
8) Window rattle elimination kit $30 shipped SOLD
9) Edelbrock rear tubular braces (w/ instructions, no hardware) $60 shipped SOLD
USED
12) Black on black Casper's knock gauge with mount and instructions $65 shipped
21) Instrument panel surround- good driver quality $40 shipped.
MORE STUFF!
25) boost solenoid w/ bleeder valve & hose $50 shipped
26) New autometer electrical oil pressure gauge w/o fitttings make offer
27) mounted mechanical gauge set (oil pressure/ water temp) w/fittings $50 shipped
28) 3" dump tube- needs to be welded in $60 shipped
29) 1987 Buick body service manual $17 shipped.
30) 1987 service manuals books 1 and 2- used (and heavy). $100 shipped
31) Doghouse gasket $5 shipped
32) new 200-R4 shifter detent plate $20 shipped
33) 2 new rear drums and 2 new rear wheel cylinders $50 shipped
there's a bunch more out there to go thru yet...:D
Ill take the last IC fan.....just out of curiosity...is it the one painted black or stock?
