Electrical connector help
psycho6cyl
Ponies Are For Lil Girls
Have this plug on an ac unit at work and need a replacement. Trying to find it with no luck. Need connector with male pins. Any help appreciated. Also if you have a cheap place to buy said connector
What is the a/c applicaton? Motor ? Brand ,model?
N2BUICK
Sorry not a conventional style home system. Thought I might have something that could be adapted. You might consider getting a pin extractor so you could get to the pin and solder on a new electrical lead ? If this is what appears what is needed?
Thx appreciate it. Yea these are definitely not conventional. Far from it. I ordered new Molex connectors and do it that way. A don' want to solder bc the aqua stats go bad. But thank you
I think he was asking if it's possible to repair the connector by removing the pins, soldering wires on the pins and putting the pins back in and reassemble.
Radio shack (if you can find one) has that style. Back when I was in the car stereo bidness, Hyfonics amps used that same style connector, in a 4 pin, for the speaker outputs.
