ECM to CCCI Module Wiring ?
salvageV6
Daily Driver
From what I can see in wiring diagrams..... the Pin A connection White wire EST line is direct from the ECM to the module with no connectors in line, is that correct?
Trouble shooting that white Pin A wire, and the tan/blk EST bypass wire and want to make sure there are no connectors between the ECM and Module that the signals pass through.
TIA :)
correct, it runs from ign module to ecm no breaks
The only wire that's broken out is the TACH wire (white) in pin E found at the green connector behind the alternator. All the rest of the signal handshake wires are direct to the ECM.
