ISSUE SOLVED 3/20/2015- thanks pacecarta !!
I have an issue some where that is not allowing my door locks, power windows, or the dual fans to work. I would assume they are related some how? I did check my fuseable links and I have power to all of them. I checked the hi/low relays and replaced with known good ones and still same issue. I put a ground to the water temp sending unit to see if that will turn on the fans and still nothing. I did take a pen light to the fuse panel and found that 25 amp AC is not getting power on either side of the fuse. And yes I did the the key on. ANy ideas where I should look next. Thanks in advance for any help you guys may be able to provide.
