Do I have a problem?
dank GN
BlackArts Automotive (661)993-8277
The stock turbo is just making heat past 20-23 psi . I would check out a entry level turbo and a better converter. I was in the high 11s with a te60 , 3000 stall lock up , and fresh valve springs 981s . O and alky
Mr.Spool
i have had them at 30psi and run them into the 11s with the boost up it always went faster.ed brewer ran his all in as well and he went 11.3 on the stock turbo and stock motor even intercooler with just a dutt neck. alky does tame the heat down ;)
