I'm still having disappointing results when I run alky and pump 91 (CA). On straight pump gas I can run ~15 psi without KR, and only 17 PSI with alky set at ~8. Engine has a small roller cam, mild ported stock iron heads, 6265BB turbo, 21* WOT timing. Fuel pump delivery tested and verified good.
Alky Pump tested with the PAC controller set at ~8 (no numbers on my controller), using Razor's tester, 13.0V supply (though my car operates at close to 14V):
- Pump comes on at ~7psi
- Pump hits max at ~18psi
- Max test gauge PSI reading: ~110
- Volume through the test nozzle 910 grams per minute = 120.4 pph = 18.2gph (@6.6#/gal of methanol)
- Volume through up pipe nozzle: 995 grams per minute = 131.6 pph = 19.9gph (@6.6#/gal of methanol)
