juan89 Active Member Joined Oct 22, 2008 Aug 22, 2013 #1 Does this tensioner work on our engines ? ACDelco 25535668 Timing Chain Dampener Assembly It is from the newer 3800 engines. Juan
P Paul Lohr Member Joined Jun 11, 2010 Aug 24, 2013 #3 I don't have an answer but I do have a question. Since the gear is missing from the front of that camshaft, are you going to run the 3800 style cam sensor rather than the distributor style cam sensor?
juan89 Active Member Joined Oct 22, 2008 Aug 24, 2013 #4 I am going to use the stock distributor gear cam sensor. I am ,also using the TA performanc billet and link chain set up.
ek02 Well-Known Member Joined Jan 31, 2008 Aug 25, 2013 #5 PM charlief1. I think he has used that tensioner on a 3.8.
M moose102 Moose Joined Jan 13, 2008 Sep 17, 2019 #8 slamming 6 said: They work fine on our cars. Click to expand... I would have loved to use this tensioner but It Will NOT work. The timing cover cannot be mounted using this tensioner.
