SpeedRacerX
Took a nice little drive yesterday. Temps about 45. Drove for 15 miles, no issue. In recent weeks, car has been running great. 93 and Alky. Usually 24-25# boost. 6262 turbo, HD actuator, front mount, 295 drag radials.
Getting close to home, I decided I wanted to stretch its legs one time for the week. I opened the dump. Turned the corner at my usual rural farm area road and nailed it.
Seemed strong through 1 and 2. As it shifted from 2-3, in a blink of the eye, the light on my tach lit up, felt like either a tire spin or a shift slip and right in that split second as I was lifting, I looked at the boost gauge and it was climbing toward 30#. Oh crap. I backed out in a fraction of a second. Checked the scanmaster and the O2s where low 700s but it showed about 7 knock. Hmmm. Had me concerned.
Got home, ran fine, no leaks, nothing visible, oil looked fine, coolant looked fine, etc.
Trans was built this Spring and I've never even taken it to the track yet so I can't imagine it was a trans slip.
I wonder if it over boosted, broke the tires loose (45 degrees) and caused it to rev up which set the shift light off??
If it was overboost, was it the cold weather and opening the dump that caused it? The wastegate hole in the turbo was opened up when the new turbo was put on this Spring.
Any thoughts?
Any thoughts?
