Delete/bypass ABS VI, Regal LS 97
strider
Hi!
Anybody have experience in Deleting/bypassing ABS VI in Regal LS 97 (or any other car with ABS VI).
Need to connect wheel brake lines directly to Master cylinder.
Is it better to keep the original master cylinder or there's more suitable from another car? If yes, what car model?
Is there a set of parts for this job?
Or could you advise which parts I need?
Its diagonally split brake system. Master cylinder has 2 pistons.
Photos of master cylinder and ABS attached.
What wheel to connect to primary piston? (I know its diagonal, but GM book doesn't specify which diagonal/wheels is for primary and secondary pistons)
IMG_20210309_194353948_result.jpg IMG_20210310_222559903_result.jpg IMG_20210312_195457892_result.jpg IMG_20210312_195759858_result.jpg IMG_20210312_195753508_result.jpg
strider
Is there a compatible Master cylinder for Regal LS 97 that has bleed screws and doesn't require ABS?
Current Master cylinder bolts directly to ABS and cannot be used without ABS.
