Decoding my RPO codes
El Corvino
Not sure where to post this, and I don't expect anyone to do my homework for me so I did as much research as possible... A few people have seen some of my options and said they are kind of uncommon / rare... I'm sure many of you have them, but would this be considered a highly optioned vehicle or run of the mill GN from 87?
Also, when decoding I saw some things in the description that said "nc and aow" Would someone mind filling me in on what that means?
I spent a bit of time going through and looking up every single RPO code. Some info I found was very specific, while other info was vague. If I have anything incorrect or that someone could elaborate on?
This is for my 1987 Buick GN with T-Tops...
1987 WE-2 Option -- Regal Grand National
1G4GJ1177HP442110 115651 J47
1987 Buick
J47 Regal Coupe, 2-Door
AC3 - Power Seat Adjuster, Front Seat, Power, 6 Way, Bucket, Driver
AR9 - Seats, reclining bucket (includes recliners & D55, nc with WE2)
AU3 - Power door locks
A01 - Tinted glass
A31 - Power windows
A90 - Power trunk release
BD1 - Insulation, Acoustical Pkj
B51 - EXTERIOR ORNAMENTATION (Molding, Rocker, Extra Wide)
Is this in reference to the badging?
BV8 - ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER
BW3 - ORNAMENTATION, EXTR ROOF WINDOW TRIM, PAINTED
BX1 - EXTERIOR ORNAMENTATION FRT END SPL
BX5 - ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED
BY4 - I/P NAMEPLATE APPLIQUE "GRAND NATIONAL"
B19 - STEERING WHEEL HORN CAP EMBLEM
B24 - ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
B71 - MOLDING WHL OPENING, COLORED
B72 - ORNAMENTATION, EXTR MLDG, BELT REVEAL, COLORED
B77 - ORNAMENTATION, EXTR MLDG, W/S REVEAL, COLORED
B79 - ORNAMENTATION, EXTERIOR, RR END
B88 MOLDING B/S, CUSTOM
B89 ORNAMENTATION, EXTR MLDG, RR WINDOW REVEAL
B91 - D
oor edge guard (black aow/W02, WE2)
CC1 - Hatch roof (na with C95)
CD4 - windshield wiper 2-speed; with low speed delay feature (if with D55 then req. N33)
C01 - ORNAMENTATION, EXTR EMBLEM, BODY, VAR 2
C18 - ARM & BLADE, WSW (WIPER/WASHER/WINDSHIELD)
C49 - Rear window defogger-electric (req'd NY state)
C60 - Air conditioning, manual (nc with WE2)
D35 - Mirrors, outside rear view; left remote - right manual (nc with WE2)
D55 - Console, full length, operating (nc & aow AR9)
D64 - Visor vanity mirror, lighted; passenger side
D71 - GEAR, SPEEDOMETER DRIVEN; #25524925
E5Z - ADAPTER SPEEDO. DELETE
FE3 - SUSPENSION SYSTEM, SPORT
FFL - FLINT, MICHIGAN, BODY PLANT 1 (BOC)
GMD - GMAD PLANTS (PLANT CODE)
GU6 - AXLE REAR, 3.42 RATIO
G80 - Limited slip differential
G87 RING GEAR, 8.50 INCH
J41 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
J50 - Power brakes, front disk
K09 - GENERATOR, 120 AMP
K34 - Cruise control, electronic
LC2 - 3.8L (231cid) sfi turbocharged v6 with intercooler (Req Y56+C60, nc with WE2)
MW9 - TRANSMISSION, 4-SPD AUTO (THM200-4R)
MX0 - Automatic transmission with overdrive (na with LD5, nc with WE2)
NA5 - EMISSION SYSTEM, FEDERAL, TIER 0
NP5 - Leather wrapped sport steering wheel (aow WE2, Y56)
N33 - Tilt steering wheel
N83 - Wheels, chrome plated, 15" (4) (aow WE2)
P0N – Pontiac??? Why the hell do I have this code?
QYH - tires; P215/65R15 steel belted radials, white letter (
req Y56, WE2)
TL6 GRILLE, BLACK
TL8 FLEET INCENTIVE, SM&P CONDUIT CO, INC
TT5 - Headlamps, tungsten halogen high beam
T43 REAR SPOILER
T47 COMMERCIAL BODY, PROVISIONS, UNION CITY BODY
T63 - Headlamps "ON" indicator
T82 - Headlamp control; twilight sentinel
T83 HEADLAMPS, DR, SPECIAL
T93 LAMP, TAIL & STOP, SPECIAL
UA1 - Heavy duty battery
UQ1 - RADIO PROVISIONS, FOR STEREO
US7 - Automatic power antenna (aow W02, WE2)
UW4 - Concert sound speaker system (req UM6, UM7, or UX1)
UX1 - radio; etr am/fm stereo with seek/scan+cassette+graphic equalizer+clock (includes U66)
U66 - radio speakers, extended range, dual rear
U23 - trip odometer (nc with LC2, U52, WE2)
VH6 BAR -- RR IMPACT (BLACK)
VK3 front license plate bracket (if state requirement)
V73 VEHICLE STATEMENT USA/CANADA
WE2 - Grand national package (includes LC2+FE2+D55+D35+NP5+C60+QYZ+N83+3.42:1 axle+spoilers+other specific interior features)
FE2 - Special gran touring suspension (aow Y56, WE2)
QYZ - Tires; P215/65R15 steel belted radials, blackwall (aow WE2)
WG1 - Power 6-way seat, driver's side
YR1 SEAT, FRONT (CUSTOM)
YS1 SEAT, REAR (CUSTOM)
YT1 BUILD-UP, CUSTOM DOOR AND QUARTER
YT9 SPECIFIED, DIVISION INSTALLED (FISHER)
19U PRIMARY COLOR, EXTERIOR, LAMP BLACK
6YX SPRING, LH FRONT
7YW SPRING, RH FRONT
8PZ SPRING, LH REAR
82C TRIM COMBINATION, CLOTH, MED DK GRAY
82I INTERIOR TRIM, MED DK GRAY
829 SEAT BELT COLOR - MED DK GRAY
9SJ SPRING, RH REAR
PON Pontiac Assembly Plant Pontiac, MI. They did the final assembly of the body and components. G80 Posi
That's kind of what I am looking for... I was curious if any of the add on's at purchase made the vehicle rare. My GN has quite a bit of rust on it... Drive train is 100% solid though. If it had anything that made it stand out and seem kind of rare, I was going to restore the body back to show... if not, I was going to buy a roller and just transplant my drive train. I figure I'm looking at roughly 60 - 70 hours of labor taking care of the rust. So I was weighing out my options.
Just curious?
Do people really pay extra for a grand national if it has certain options that make it rare? I cant see how a moonroof or ac or power antenna or digital dash would make it so much more desirable than the next? Is that just me?
They all had A/c. If it is an LC2 it got c60(a/c)
Sent from my HTC PH39100 using Tapatalk
unless you are the original owner , realize we are thirty years in and things get replaced and/or added. Jack it up and spin one of the rear tires. If the other one goes the opposite direction you don't have a posi.
with that t-type you should also have the g87 and gu6 for the 8.5 axle and 3.42 gears.
