1988 Olds Cutlass Turbo LS
87chrisss
BLUBYU
Price is $40,000 OBO.
1988 Cutlass Turbo LS street car with cold ac on E85
Iron Block 6 liter -Fully Built w/receipts in hand. its a 408 stroker assembly ARP throughout Moroso High Clearance oil pan
243 - Z06 alum heads race ported cometic mls HG ARP studs.
Custom Turbo Cam / crane rockers w/ custom pushrods ls7 lifters
Forced Inductions S485R V2 t6 1.32 , Hooker Manifolds with custom x-over by KFAB Billet T6 flange - priority gated JGS performance 500r vband WG Custom 5" to 4 downpipe. RJC Racing Intercooler Set of Turbo Smart BOV
Edelbrock Pro Flo w/SnakeEater GB1400s
ATI damper
4l80E with all Billet Internals and T/brake auto v/b from CK performance receipts and pics available. PTC 9.5 Dusty spec'd TCI FlexPlate
Chromoly 3.5" Drive shaft Gforce Xmember Metco Loop
Quick Perf 9" 40 spline 5/8 studs 3.50 gear Wilwood front and rear brakes Spohn ARB
Metco upper and lowers. Holley Terminator X Dakota Digital Cluster Grand National stock style tank with internal baffle Twin hellkat 525s in tank second pump comes on with pressure switch at 5 psi
Cold Case Radiator Twin Maradyne fans.160 deg thermostat. Transmission fan/cooler under IC
RC components 17" fronts and 15" rears 275/60/15 mt et pros brand new NO RUST clean clean. will drive anywhere ac blasting Makes a lot of power runs great. 305 miles on this setup. no issues have videos and truck load of pics.
Not my first rodeo no junk if anyone needs a reason for why im selling is because i ordered a f150 4x4 coyote im going to turbo build.
Dont need cash dont even try to low ball. Will consider a trade only for a clean buick rare optioned/color combo.
786-487-9775 Miami , FL
Just here to say that this is my dream. There is one of these I pass every day, same color, with the stick wire hubcaps. I’ve always said I’d move to stick a crazy LS in it, widen the stock wheels so I could leave the hubcaps, then do like 4 mufflers on it with a cutout and drive it around looking and sounding stock….until it was time. Awesome build, and right about 1000hp is crazy.
