Putting the 87 back together after a year... couple questions... the car had a hot wire kit and i installed a double pumper with the harness and switch for the second pump... do i need to re install the hot wire kit or dose the harness take care of the the same duties... second question is a wiring one... figured out most of the harness but two plugs.... there is a square 4 wire plug that come out behind the the engine.... its like the plug the goes under the throttle body.... the second one is a single black with orange strip wire with brown plug that comes out behind the windshield wiper motor... ill try to post pics but havnt been able to...
thanks
eric
thanks
eric
