I have a vigilante 3400stall L/U and I think it may be going bad. Here is why: After I get on the throttle and let back off it shoots fluid out through the filler tube. this only happens when I get on it. I have checked and I do not have any obstruction with the lines and all flows properly. The fluid is not over filled. If I drive the car normally and not heavy acceleration then it does not happen. I figured when it increases pressure it shoots it out the filler tube if the convertor is not working properly. Am I on the right track? Any thoughts on this?.
