Connector identification
spross86
Can anyone tell me what the connector is and where it plugs into? Just installed the new motor but I can’t find what it’s for?
Colors are Black-Brown-Graypink with black tracer.
egr solenoid
also can serve as connector for XFI fuel oil logging with the casper adapter
Ok gurus, can you ID both this three wire connector and the vacuum operated something on the passenger side fender?
thats for a map sensor for the led boost gauge on the analog cluster , the vac cannister is actually a boost switch and turns on the boost lights in the digital dash cluster and should have a plastic vac line that runs to the steel line at rear of plenum that runs up to the vacuum block at the top of throttle body
on analog cars that 3pin map sensor is dead because theres no connection to the dash at the c100 connectors
